clio 16S hibrid
clio 16S hibrid
Hi i´m from Spain and i i´m preparating a clio 16s with block williams. I want to ask you what are you recomendations bout the engine, about electronic (ECU) ans suspension. Many thanks
Re: clio 16S hibrid
i understand french but i don´t write it very well sorry
Re: clio 16S hibrid
Hi Marcus,
So I reassure you that I understand and do not speak English well I understand your point.
For the preparation of your car with the engine williams, there may be level.
is what you want instead of a car for road use or for the circuit or rally?
Tell us what you want, after you help you!
cordially philippe
cordially philippe
Re: clio 16S hibrid
My clio it´s for street use only not for rally or track use. tonight i´ll put some pics.
- Miaouw67
Re: clio 16S hibrid
for the engine, you can take some forged pistons with high compression ratio.
H conrods for low weight => high RPM
Re: clio 16S hibrid
the engine it´s closed
what is the way to upload photos??
- Miaouw67
Re: clio 16S hibrid
you can use imageshack.us to upload pictures
if the engine is closed, you can change the exhaust manifold, the cat back, group A intake system
Re: clio 16S hibrid
and the camshafts in nearly future.
Re: clio 16S hibrid
i´m thinking in bilstein suspension, megane rs brembo calipers (with 280mm discs) and speedline gr a wheels.
another cuestion: What height is the best for the 16s, -2cm, -3cm ...?
